AKincer
Long time lurker - first time poster.
I'm starting work on a basement bathroom. Plumbing was roughed in when the house was built 10 years ago. Attached is an overall photo of the area showing the shower drain and vent, wc drain and vent, and sink drain and vent.
Shower drain will need to be moved a foot or so to accomodate my plan. Concrete has already been busted up.
WC is fine right where it is.
Second photo shows the sink drain rough in. I need to move it over about a foot to the left. I assume this is as easy as cutting out the santee (Location A) for the trap arm and replacing it with one that is rotated 90 degrees. I'll move over a foot with the proper elevation change (1/4 inch per foot) (Location B) and then make the turn to come out in the middle of my cabinet. Question is what is the proper fitting to make the turn at Location B?? Also, does it make sense to then use wye as I exit the wall under the cabinet (Location C) in order to provide a cleanout at this location.
Any help you can provide would be great!!
