Hey Guys I am new to the forum here but have tons of experience in everything about remodeling except plumbing and electrical. So, I plan on being a resource, but right now i need your advice.
Project: To add a extra bathroom and utility area below existing drains in house.
Questions:
(1) Are there any special pumps or macerators needed for sewage?
(2) With roof venting available, do I need to vent the pump or just the toilet, shower, and washing machine before the pump?
(3) Is it okay to tie into kitchen sink/dish washer drain or should I plumb past those 6 feet (horizontal) to tap main 4" drain pipe.
(4) Can this type system be installed in crawl space area under floor if access can be made?
(5) should we add a extra hotwater tankless?
(6) Do new front load high capacity washers discharge more or less water to the drain?
Details: Existing drain for kitchen sink is 3+ feet above area for new construction. We plan on adding a shower, toilet, vanity sink, washing machine and utility basin. Roof venting no problem as walls need to be built.
I am hoping something like the DAYTON 4RK74 will do the job.
Thanks in advance for your time and advice.
--Chris (Tulsa, Ok)
Questions:
--Chris (Tulsa, Ok)
