Vacuum Breaker Issue
jlsddmar
Watertown, MA
Hi Guys -
I just finished installing a hand shower and had had some issues with the vacuum breaker. Every time I tightened the breaker to the supply elbow with the washer included, the washer would compress down against the slits, and would prevent the water from coming through the breaker.
I have everything working now without the washer. All of the connections were Teflon taped. Is the washer necessary? If so, do you know why it keeps getting forced against the openings?
Thanks,
Derek
Shower Washer Prob.
Without knowing what type and brand of hand shower you have I can't answer, sorry. :(
Vacuum Breaker
Hi -
The vacuum breaker is an Alson's 4900. (http://www.alsons.com/accessories/hoses/products/docs/ACC_VB_4900_instr.pdf)
The only thing I'm not sure of is whether the washer is only for sealing purposes, or if it functions as part of the breaker (and therefore isn't working correctly without it). Either way, I still don't see how the breaker could be fully tightened without having the washer completely block the slits.
-Derek
I'll just go without it then. Even hand tight is enough to block the flow when the washer is in there. Looking at it, I don't see how it could possibly work with the washer in...
