Tapping into a flexible water line
cacherjoe
New Brunswick, Canada
Folks,
I'm hoping someone can help me. I am about to install an inline humidifier in my furnace. The instructions are all geared to copper water lines, I have flexible water lines. With the kit there is a "saddle" type valve that is used to tap into the waterline. I'm thinking that this won't work well on the flexible waterlines I have in my house.
Can anyone confirm that this will or will not work and if not what should I be looking for when I go back to Home Depot?
Thanks
Joe
Not only will it not work, saddle valves are not code compliant and have a nasty habit of leaking. You need to find out what kind of "flexible" pipe you have and get fittings for it.
Thanks Peter,
I'm not very handy and of course the box says, easy installation. All I can say is that the water lines are blue and red plastic covering with what looks to be steel inside. The house is only 2 years old and I'm in Canada if that helps.
Folks,
Thanks
Joe
Is it PEX lines you have? If so, about your only option is something like a TEE fitting 1/2 X1/2 x1/4. And unless you have the crimp tool to connect into the plastic line....your only option would be something like a sharkbite fitting that connects simply by pressing the lines into the fitting. You could check the big box stores for selections. Or do an internet search to see them..
