View Full Version : I Discovered A Great Way To Go Through Concrete Walls (Air Chisel)
drizler
11-26-2009, 09:46 AM
I needed to make a 6" hole through a poured concrete foundation in my basement. I got a nice new makita hammer drill masonary bit for my drill and found out how ugly it could be. Forget that. A real masonary drill costs too much and I didn't want to rent one so I thought what about my hand held air chisel. It is a cheap HF job I used a few times for cutting panels or drum tops off . Thats about all I thought it was good for. Then I tried it on the 15 year old cement. Wow does it cut. Of course it is still a 6 pack job and one hell of a mess but its a lot easier to use than a drill. Strangely it doesn't even dull the Chinese cheapo tips at all. What's best is that there is no need to lean hard on the gun and it doesn't take a monster air compressor either. Just put a little pressure on it and let the spring do the work. I bet I paid a whole $15 for the thing. Incredible. The only thing I wish I had was a longer set of Ajax chisels.
11-26-2009, 10:21 AM
Or you can get a core driller out there.
They use diamond tipped drills, and they do a clean core without any dust.
They keep the dust down with water, which also cools the bit.
It will slice right through rebar.
drizler
11-26-2009, 11:29 AM
Ah yes very true Terry, but as always its that on little thing, $$$$$$$$:mad::mad:. For you pros it is a gotta have item but for us once every 5 year slobs, well ya know.........
The problem with ANY chisel, and I have used my air chisel a couple of times but it is usually too "light" for major drilling, is that the deeper you go the narrower the hole gets.
export!
11-29-2009, 09:41 PM
Ahh.... so true with so many things in life.
Scuba_Dave
11-30-2009, 11:44 AM
I used a combination of a sledgehammer, cement drill bits/hammer drill & air chisel to get a 3-4" hole thru for drainage
It was from a crawl space under my sunroom out to my drainage pipe
11-30-2009, 01:55 PM
When I was doing new construction in my 20's, and I needed a hole big enough for a 3" waste line through the 8" foundations, I would only use a sledgehammer.
Five blows with a sledge before the back side would pop out.
And then a few more to make it large enough for the pipe.
These were fairly green walls.
If the walls have cured, then I like coring them.
