I am reading that the tub drain should be 1 1/2" while a shower drain should be 2". If a tub/shower combo is installed, can a standard tub drain be used, or does that require a larger shower drain?
What do you mean by tub/shower combo? Tub with a shower head? If so the 1-1/2" drain will work. The idea is that the tub can provide holding space for water if the drain is slow, a shower doesn't offer much if any holding before you overflow the curb.
It also works for showers too, and that used to be the size required by "Code" too. I think that bigger houses and longer distances are the reasons why its size was increased to 2".
