I would like to remove the existing toilet flange and 3" drain in the middle of the image and relocate the toilet flange and 3" to the right branch in the picture.
Question: can I use a 3" X 2" wye like you see in the middle, branch off to the left which runs to the shower trap then attach a short length of 3" PVC to the end of the wye located in the middle of the image and connect a 3" 45 and head down the right branch where my new toilet flange will be?
If not, what fittings and will allow me to creat this set-up?
Second Question: (not pictured) the shower and toilet drains obviously meet up at the wye and then continue on to the lav drain. Would running a 2" vent up from the lav to the future vent be adequate for venting the shower, toilet and lav, or should I run separate vertical vents for each fixture?
Thank you all and I hope this makes sense.............idoc
