Well pump pressure switch
peterd
Its is possible for a home owner to change the values a well pump pressure switch comes on at. Right now the pressure switch is set for about 30psi (looks more like 28psi on the meter) and kicks off at 60psi. I would like to up the 30psi to say 40psi. Is this possible without replacing the pressure switch altogether? Is the 30/60 normal or am I better off with 40/60?
Thanks
Peter
It is possible. With the 30/60 setting you get a better drawdown than with 40/60, but less pressure at the low end. The bigger drawdown is always better for the pump motor, but bad in the shower. Your call.
bob...
Bob,
If I decide to change the pressure switch from 30/60 to 40/60 do I have to worry about the amout of air in the bladder? How about if I decide to change it the pressure switch to 40/70?
To set get the correct pressure in the bladder I suspect that I will need to drain the pressure tank of water?
Thanks
Peter
Is anyone farmilar with a air-over-water-tank pressure tank? Is does not have a bladder from what Starite is telling me. So if I wish to adjust the pressure setting on the tank is it just a matter of adjusting the pressure switch?
Thanks
Peter
I have never heard anyone call a pneumatic and air over water before. Since air is lighter than water, the air is going to be over the water anyway.
Adjusting the pressure is like you say, but you will have to de waterlog this tank all the time.
bob...
Bob,
What do you mean be de-waterlog all of the time. Is the something I am suppose to be doing that I am not. The pump/well driller never mentioned anything. :eek:
-Peter
Well this is getting more fun by the minute. I went and inspected trhe tank tonight. The tank has an input from the well, an output for the house service, pressure gauge, and pressure switch. Thats it. Nothing else. There isn't an Air Volume Control unless it's part of the pressure gauge. Also from what I can tell there does not exist a drain on the tank.
Here is the link to the tank. What I am trying to do is increase the pressure from 28/56 to 40/60. I just don't want to blow anything up.
Gary, will increasing the pressure affect the erosion chlorinator at all?
Thanks
Peter
If your tank looks like the third picture down with the Air Volume Control and your gauge is on top of it. You may at one time had an air making system. I don't think we discussed your pump, so I'm assuming you have a submersible. And if the above is true, your air making device of hole in the pipe has plugged up and is no longer making air. This results in a waterlogged tank.
bob...
I will take some pictures of the tank tonight and post them. I am the original owner of the house. The tank is 18 months old.
Thanks
Peter
Increasing the pressure settings won't effect an inline pellet chlorinator. Not having the proper air pressure in the tank probably will though.
Whoever installed the tank should have used a regular (cast bronze etc.) tank tee and plumbed in a boiler drain to allow draining of the tank and also a pressure relief valve, which is code.
Gary
Quality Water Associates
Well here are some pictures of the tank. Your guys can the try to figure out what I have.
Thanks
Peter
That is a Johnson Air Volume Control (air release valve) on the side under the gauge. Apparently you had an air making system and it's not working now. If your pump is cycling that is.
The tank you have is definately not a bladder tank.
bob...
