miamicanes
11-11-2009, 01:14 PM
Right now, I have two drains in front of me... one is going into the new tub, and one is getting returned. I need help deciding which one to keep.
One is a traditional lever-type drain that cost ~$25. The other is a cable drain that cost ~$80. Both solve the one problem I care about: being able to open the drain without sticking my hand into the water. Beyond that, I'm trying to decide whether the second is really worth paying ~3x as much, just to get a dial that turns instead of a lever that flips.
From what I can tell, the one deal-breaker for lever drains is distance to the drain... they can't be used with center-draining tubs, and might not be usable with tubs that are substantially larger than "normal". My tub is right-drain, and as far as I can tell, is within the capabilities of a lever drain.
Is one significantly easier or harder to install and/or maintain than the other? One factor I thought of is long-term reliability. If the lever drain needs to be fixed, I think I can do it from "outside". On the other hand, I'm not sure whether a cable drain with cable problems (say, a cable that stretches or becomes loose over the years) *can* be fixed without access to the underside... something I won't have once the tub is installed & the room is tiled.
Does anybody have any particularly strong opinions one way or another? Although I'd rather go with the cheaper drain, it's not like I'd be bankrupted by the more expensive one if I could think of any really compelling advantage to it. So far, the one really compelling argument either way I've come up with is against the cable drain (worries about repairing a stretched/broken/loose cable if I can't get at the underside).
