tchp
11-10-2009, 04:23 PM
I have a Premier step-in safety tub that needs a replacement drain fitting, and it is an atypical fitting type (possibly European, as the tub is made in the UK), and I have not been able to find a replacement. I have attached an image. I have the black plastic flange for the overflow drain, but there is a similar flange for the main drain that I also need. It is not like U.S. style drains in that it is just a single screw that tightens the chrome flange inside the tub against the plastic flange on the outside, in order to make the connection water-tight. I was hoping someone might recognize the manufacturer and know of a supplier. I have been told that it is very hard to get parts direct from Premier itself.
