Trouble with p-trap
gregnoob
Virginia
I am installing a new pedestal sink in my bathroom but ran into a problem with the p-trap assembly...
I bought one of those kinds that has the 90 degree down turn that gets glued into the stub-out and then connects to the curved part of the trap by a big screw so that you can turn the orientation of the trap and then tighten. On the other end I glued a 1 1/2 to 1 1/4 adapter...
When I poured water through the assembly, it leaked at the big screw part (see picture).
I noticed that there in no plastic "nut" in the joint part where the leak is... Is there supposed to be? Am I supposed to do something to the joint to keep it from leaking? Am I better off just buying parts that can be simply glued together rather than mess with this "adjustable" stuff?
If that is a slip on piece then yes there should be the plastic piece. If that is a screw on part (both ends) then no.
Your pic is Sch. 40 PVC...I personaly would have opted for the 1 1/4" tubing trap...it makes this job less difficult... You should have a 1 1/4" Desanco at the wall and a tube trap and trap arm for the rest of the job...
Thanks... turns out that the threading looks bad (gouged) on the male end of the connection and that's where I am getting the leak. I've got to cut the assembly off and I'll probably go with the 1 1/4 Desanco on the stub out and then use the 1 1/4 tubular trap as suggested.
Think this is the only option to get things to line up now anyway seeing I have to cut and lose length.
Thanks all!
