Floor-Mount Rear-Discharge Guidance
dsrtdady
tucson
I've reviewed and re-reviewed the reviews and am now looking for guidance from someone in the know...
What would you recommend for a floor-mount, rear-discharge, elongated-bowl, watersense-approved toilet?
Thanks for your suggestions!
You could use a Gerber 21-310 with the 1.1 gallon tank.
Do not get the dual flush tank. They quit working in six months.
re: Floor-mount, rear-discharge guidance
Thank you - this seems to nail it.
Am curious -- why recommend the 1.1 over the 1.6? Is there a bowl clean advantage to either? (will be an issue with my wife). Also, Are both considered Watersense approved?
Thanks again for your help - very much appreciated.
Do not get the dual flush tank. They quit working is six months.
For what it's worth, the 1.1 gallon tank Gerber uses is a variation of the dual flush using the same tank and handle/actuation mechanism. The only difference is that it's a single flush with reduced volume.
