removing rusty drain from antique sink
peeler
Kannapolis, NC
I'm restoring a 1923 Kohler pedestal cast iron sink,, and having a bit of trouble
removing the drain pipe. There is rust between the pipe and sink body. I've been hitting it with spray oil periodically, tapping it with a hammer. I'm assuming the visible flange ring is attached to it permanently but not sure...
any ideas? would a little heat be effective, safe?
I'd be worried the sawsall would vibrate and chip the enamel as well. Any chance you have a dremil or a diegrinder/cutter? If you try the sawsall, use a good sharp blade....
A little heat would probably get it off, but like HJ said, it could pop the enamel. I think I used a diegrinder to cut the one off my antique clawfoot tub!
If you have the sink out just simply cut the drain off with a hacksaw as close to the underside of the sink as you can. Make sure you cut/pry off the nut holding the drain in place.
Good luck!
