expansion tank issues
James W
Richmond BC
Just had an expansion tank added and now have a whistling noise at the pressure valve when flushing a couple of toilets and seems to be lower pressure in the system. why would an expansion tank have affected flow?
Did you use a gauge and air pump to balance the pressure in the expansion tank to match the PRV pressure setting? I'm not sure what an imbalance would do, but they are supposed to be balanced.
I have never ran into this problem per say but generally that whistling noise comes from the PRV when it's gummed up a bit or not acting properly. The velocity of the water makes it whistle at high speeds. You can also get the same sound from y-strainers etc.
I hope this helps.
Prv
IT doesn't. Whatever happened is coincidental to the tank's installation. If you had to turn the water supply off, the valve could have failed when it was repressurized.
blocked connection
if one of the connections had been oversoldered when installing the tank could tis have caused a drop in pressure? very high whistling noise when flushing toilets after installation complete
Change the PRV. Whistling, humming, vibrating all happen when the disc in the valve has worn over the years.
