Water Coming out of Pressure Valve
Chenzo
Michigan
Came home yesterday to find that I had no water pressure. I had over the last month or so noticed that the switch on the pressure tank would click/contact excessively turning on and off whenever water was running. back to last night ---I removed the differential pressure switch cover and could manually make contact with the switch and water would flow from faucets etc. Replaced the switch with the same type 30/50 and it kicks on itself again and we have running water. The problem still remains when water is running it turns on and off excessively. I went to check my tank pressure and water comes out the valve. Is this a dead tank, leaking bladder or something of that sort, and I need to replace it? Model is H2Ow-TO.
Yup that is the classic description of a shot bladder tank...
Thanks for the feedback, from what I've been reading I figured I would need to get a new tank. Any suggestions on a tank that has a bladder vs diaphragm or are they the same?
Now might be a good time to ditch the switch and get a CSV and a smaller (much smaller) tank
Peter Griffin is right install a Cycle Stop Valve www.cyclestopvalves.com or better yet purchase their Pside-Kick. I comes with everything you need including a small tank. This will give you a constant pressure like city water pressure and make your pump last longer.
Porky Cutter, MGWC
National Ground Water Certified, "Master Ground Water Contractor"
Hey, thanks for the information and advice it has been very helpful in helping me make some decisions. I will consider the CSV.
