russjs1123
I have an above ground 3/4 HP flo-tec well pump operating off 110 VAC. The original pump was running in "hard then soft" rapidly every time water was drawn.
The new pump is doing the same thing.. ALSO...the new flo-tec 46 gal tank is not filling with water, even after I close the ball valve after the tank!
Water is in the system because it is coming out of each outlet in the house. The pump is getting very hot and actually shut itself down for a short time (probably from the heat). The pipe to the tank is 1/2" copper. I am new to this, so any advice you can give would be great!
Thank you!
Thank you!
