View Full Version : Shutting off water for winter?
Bigmamma
10-22-2009, 12:14 PM
We have Toto Guinevere toilets in our new Wisconsin vacation home. We have well water and use a water softener. We keep the heat set at 60 but were going to drain the pipes and shut off the water for the winter to eliminate pipes possibly bursting. Will this cause any damage to the toilets? In my older vacation home, we would get hard rust stains in the toilets which were very hard to remove. Don't know if this will happen in this house. With the sani-finish I don't know if that would be a problem if it did happen.
Gary Swart
10-22-2009, 02:39 PM
I would have a couple of concerns. It is very difficult to be sure all of the water will drain from pipes by simple gravity. There are almost certainly going to be low spots that won't drain. You should have the pipe blown out with compressed air, but do not blow air into the toilets. P traps should be protected from freezing as well, but they need to remain full of liquid to block sewer gases and vermin. Some folks use cooking oil, other like RV anti-freeze. (NOT automotive) The toilet bowls and tanks need to be drained, and the toilet traps protected with oil or anti-freeze.
