View Full Version : Advice on flange problem
Kitch
08-18-2005, 05:18 PM
I recently removed a vinyl floor in my bathroom and replaced it with ceramic and CBU. This increased the floor height by 3/4in. When reinstalling the flange, I'm 3/4in short. What are my options?? The flange is copper and connects to a 3in copper soil stack. I'm installing a TOTO Pacifica when I fix the flange problem.
Thanks,
Kitch
Mad Plumber
08-21-2005, 03:21 PM
Kitch,
You can get thes stacking things from oatey, that will brang teh flore flange gup.
http://www.oatey.com/apps/catalog/showskus.asp?ctg=11&subctg=3&prodgrpid=107
Kristi
08-21-2005, 04:56 PM
you can get one of the wax rings that have the plastic collar on them, a "Cant Leak" wax ring - they make a sort of chute down to the drain, so there will be no problem with your floor height.
Kitch
08-25-2005, 03:36 PM
I appreciate your posts. I guess I need to explain myself more or get add'l explanations from you. After increasing the height of the floor by 3/4in, and then reinstalling the closet flange on top of the new ceramic (as it should be), there is a 3/4in gap from the bottom of the closet flange to the top of the soil stack. I think that when it was recommended that I use "stackers" (would that be several wax rings or a similar device?) the assumption was that I left the closet flange as is and the new floor rose above the flange. This is not the case. I need a way of closing the gap from the copper soil stack to the bottom of the copper flange. Could I use a 3in Fernco?
Thanks,
Kitch
Kitch
08-25-2005, 03:38 PM
I looked at your link for "stackers" and they unfortunately won't work. I believe that they are for increasing the height of the closet flange when a new floor is installed around it. Thanks for your help though!
Kitch
Kristi
08-25-2005, 04:08 PM
ahh yes, the misunderstanding here is that usually when you raise the floor (by tiling) you leave the flange behind on the plywood flooring and cut around it which makes it a far stretch for your toilet to seat and seal properly. You don't want to have anything causing hangups in the drainage, we want a smoooooth ride all the way for every flush. Can you get a pup piece on the end of the flange so that it reaches the drain all the way? Then I'd use the fernco or preferably get a coupling on...
Kitch
09-08-2005, 05:07 PM
Here's what I'm going to try. Cut off a portion of the 3" copper soil stack, mate some 3" PVC with a Fernco, and top it off with a new PVC flange. Does a Fernco leak over time? Thanks.
Kitch
Kristi
09-08-2005, 09:01 PM
nope... the fernco is trustworthy.
RioHyde
09-08-2005, 09:30 PM
You're going to want a mechanical coupling like the Proflex made by Fernco. The Proflex will allow you to transition smoothly from copper to pvc and make a nice solid connection. Avoid just using a regular rubber coupling with the hose clamps. These are not made for transitioning between two different types of materials.
