View Full Version : Moving shower drain a few inches.
piperca
10-18-2009, 07:53 PM
This is what I've got. Where the lines on the floor intersect, is where the center of the drain needs to be:
http://i275.photobucket.com/albums/jj316/piperca/SDC11179.jpg?t=1255917353
Using a 45 degree street elbow and a new P trap, this is what I came up with ... can I "legally" do this?
http://i275.photobucket.com/albums/jj316/piperca/SDC11180.jpg?t=1255917458
Here's a side view:
http://i275.photobucket.com/albums/jj316/piperca/SDC11181.jpg?t=1255917566
BTW: A big "thank you" to my wife for holding the pipe ... :D
johnfrwhipple
10-18-2009, 09:54 PM
I'm sure this will will work but safer to wait for a ticketed plumber to chime in.
If you install a Schulter Drain you have a little more offset room and it might just make it bang on.
Good luck.
PS. You are only aloud so many degrees bending in a line and the plumbers will need to know where that line runs off to.
piperca
10-18-2009, 10:25 PM
The line travels directly to the 3" stack.
I believe you're allowed 135 degrees change of direction ... I'm not sure how many degrees would be considered in this run.
I'm installing a Schluter Kerdi shower and will be using their drain.
Gary Swart
10-18-2009, 11:03 PM
What about the vent?
piperca
10-18-2009, 11:08 PM
This is existing. The shower drain runs directly to the 3" stack (36") without any vent. I believe it doesn't need any additional venting ... and if it does, I wouldn't know why, since it works perfectly without one.
johnfrwhipple
10-19-2009, 07:21 AM
This was a shower only before - correct?
I think you can we vent your 2" line the 36" you have and have no concerns - especially after you have used it like this in the past.
Are you changing the use of the room or making any structure changes? If not you can go ahead with no permits. With Mike Holmes and Brian of DIY I have noticed a spike in permit request from my clients.
Many more realtors are searching for permits and negotiating discount s for their clients when none found. Are you flipping this house?
Cover your basis. If you are selling go down and pull a home owners permit for this job. Chances are they will send you away. If so make a notation of that in a job file and take pictures and video of everything you do in case this comes up one day when you decide to sell.
Good Luck.
K.
10-19-2009, 08:45 AM
My experience with the permit was as you imply. I had to insist on getting one at the permit office as they weren't interested in what I was talking about at all. Then when the inspector came for the rough-in work he also seemed relatively disinterested, certainly wasn't looking to bust me on anything like Mike Holmes might have! But the process definitely applies to a future sale; with the growth in do-it-yourself renovations that are facilitated by forums like this, especially this year with the stimulus spending (in Canada anyway), it makes sense that some agents are picking up on it as a negotiating point.
-Jonathan
piperca
10-19-2009, 09:38 AM
No, I'm not selling the house ... I'll probably die here. The kids will get it, someday, and they can deal with any issues then, LOL!
I am making sure everything is acceptable under the code before I do it. I am a carpenter by trade, but plumbing is somewhat new territory for me. I know how to sweat/glue pipe, but that's it ... that's why I'm on here.
So, what's the consensus on the P trap; am I okay with it?
piperca
10-19-2009, 03:23 PM
I couldn't wait, so I went ahead and installed it.
I researched and read that it doesn't matter what angle the trap is set at, since water doesn't know what direction it has travelled, once it has made the loop in the trap. The only angle that matters is the 45 degree fitting that is on the horizontal ... correct me if I'm wrong!
http://i275.photobucket.com/albums/jj316/piperca/SDC11182.jpg?t=1255987448
iminaquagmire
10-19-2009, 03:44 PM
Try it. Dump a 5 gallon bucket quickly down the drain. If it drains okay with that, it'll drain okay with the shower going.
10-19-2009, 03:55 PM
Other than appearing odd, there is nothing wrong with it. I might have broke the concete back a bit and installed the trap directly to the horizontal arm, but that would just be a personal preference.
piperca
10-19-2009, 05:03 PM
Thanks guys!
I agree, hj, it would have been better doing that, but I am done breaking out concrete ... I just couldn't bring myself to do it!
