View Full Version : Using existing tub water/drain for sink
Fidget
10-17-2009, 12:14 PM
Im installing a wet bar sink on the backside of an existing bathroom wall that has access to the tub overflow drain pipe as well as the 3/4 water pipes serving the tub from the main. I want to T the sink drain off the overflow drain coming from the tub and run the water off the tub water pipes. I dont know if this is to code or not. The sink drain trap and vent (interior) will be prior to drain pipe entering the wall and doing a 90 degree down to the overflow pipe on the tub. If T ng into the O/F drain is not good, I have, close by and accessible, a 4 inch sanitary stack with clean outs that I can tap as well. Again, dont know if this is doable via code. I live in Virginia and will be going to the County offices on Monday. Just want to know if Im in the ball park.
Fidget
10-17-2009, 02:48 PM
Neither one should be acceptable to the building department, but for different reasons.
