That is provided it extends into a heated space where it actually shuts off. I say this because a customer had one freeze and burst but the seat end of it was still inside the exterior wall, the contractor who originally installed it did not use a long enough model. And don't forget to remove the hose and if you have one on, the gated wye. In the spring I replace numerous burst freezeproof faucets because the hsoe was left on all winter. Then once you turn it on to use it in the spring it starts to leak.
