pbaxter
10-06-2009, 10:36 AM
Have a 2-story house with one-zone hydronic baseboard heating (upper and lower floors are piped separately, but only one thermostat). This is an old house with heavy cast-iron baseboard radiators.
All rooms get heat EXCEPT one room on the upper floor. Naturally I expected to get air when I opened that room's radiator's bleeder valve. Instead I got lots of cold water and no air coming out (circulating pump was running).:confused:
What now? Clearly water is getting into this radiator -else I wouldn't get (cold) water out of the bleeder. After bleeding, the inlet side wasn't even a little bit warm.
Could the outlet side (downstream of the bleeder) be clogged?
Could the inlet valve be faulty (only letting water flow when there's a big pressure differential)?
Any and all suggestions will be appreciated
