View Full Version : drip drip drip
nothingeverworks
09-29-2009, 10:06 PM
there is probably an easy answer to this question. i just removed my bathroom vanity and faucet. And of course I completely turned off the water supply valves first.
Unfortunately one of the valves won't stop dripping. (I did leave the the braided connectors attached to the supply valves but i can't imagine that having anything to with it.) so i am guessing that i need to replace the valve?
D'Brie
09-29-2009, 10:31 PM
I don't know the age of your stops and supplies but I would replace them all. They're not expensive, you'll have peace of mind but you may need a stop puller tool if your stops are on copper. Good luck. :)
Gary Swart
09-29-2009, 10:59 PM
There are new style stops that are 1/4 turn.
nothingeverworks
10-01-2009, 06:14 PM
The stops are connected top copper. in fact are soldered. Will a stop puller tool get the valve off or do i need to call a plumber to blow torch them off?
jadnashua
10-02-2009, 10:44 AM
If you decide to replace, you'll need to unsolder the existing valves unless the pipe is long enough to cut them off and still install a new valve. As noted, you may be able to just replace a washer, but the seat (the part it seals to) may be bad as well, and a new washer may not do much.
nothingeverworks
10-02-2009, 11:34 PM
i appreciate all the replies. one last question. i unsoldered the valves and put on new compression valves. i was going to use teflon tape to connect the supply lines. should have i also have used teflon tape on the compression nut connection too?
jimbo
10-03-2009, 04:47 AM
NO TEFLON TAPE in this picture any where. NOT on the compression fitting, and NOT on any connection to the supply line. It will CAUSE a leak.
nothingeverworks
10-03-2009, 05:40 AM
well that's about as clear as it gets. thanks.
