tub drain rough in
Jwray
Virginia
How far do I have to go with a tub drain rough-in. Is it just up through the trap or do I need to install the tub along with the drain and overflow assy? This will be inspected rough-in and final.
Also, if to the trap is enough, how do I put the tub and the drain + overflow assy in later? I have access from below right now, but will probably not later on. However, I may still have access through the wall from another room to the drain end of the tub later on. This is all glued PVC DWV.
Thanks,
Joel
