Very simple. After the shower head is removed, put a ball valve on the pipe, then go from that with fittings to reduce to an air hose quick coupler. Don't turn the air into the system until your faucets are open, the air compressor has too much pressure for the faucets and valves. You will need to have the farthest end of the system open or it will not drain completely. I'm not sure that's where I would attach the compressor, but it will probably work.
