new well in Tomball TX
haysie
tomball TX
Just need some advice.
I have 2 quotes in the $6k range, what should i be looking for?
House is 5,000 sq 2 story with about an acre of land
already have installled speinkler sytem so what will give me a good flow with good pressure
thanks for any advice given
You will need to know how much water the sprinkler system will use.
Do you know how many zones?, and how much water each zone uses.
That information is something the driller or pump installer will need to size the pump correctly.
On most home sprinkler systems, a 18gpm, 1.5 hp submersible pump with a 220gal none bladder tank will work great.
Your quote sounds kinda cheap.
How deep are the wells were you are, and what stuff comes with that quote?,,ie:: pump, tank, casing, (drop pipe(steal or pvc)?
Travis
Travis thanks i will be getting all the info today and will post as soon as i get it
thanks again
well is 220 feet deep
2hp pump
sprinklers we have 18 zones
think pvc piping
not sure of tank size
we are in tomball texas
Why a 2hp?
Your well is not that deep. A 2hp is for a deeper well with a lower water level.
A 1.5 should deliver plenty of water at a cheaper price and, at a low cost of electricity.
A 1.5hp can deliver around 30gpm, or are you needing more water than that?
I just cant see any reason for that size pump.
Or am I missing something?
18 zones on a about an acre of land!?
With that many zones on a small lot, each zone should not use all that much water.
I have no idea how big or what kind of spray heads you are using, it just doesn't make sense to me.
Travis
It may be a jet pump?
I think they are talking about a shallow well jet pump. . . waterwelldude is probably thinking submersible pump so $6K probably isn't out of reason in that area. I suspect a high water table.
Other than that Waterwelldude is right.
Porky
Porky
Yes, I was thinking submersible. Thanks for pointing that out.
Travis
