I understand different pressure switches, or settings, will effect the amount of drawdown of water in the pressure tank. Does the pressure switch effect the water pressure I will have at the shower, faucet, etc..? I currently have a 20 gal. tank with a pressure switch that is set at 48/68 and the water pressure is OK. I'm going to replace this with a 62 gal. or more tank. Do I just pick a pressure switch that will cause my pump to run for at least one minute? Will a 50/70 switch give me better water pressure than a 30/50 switch?
Thank you.
Thank you.
