View Full Version : Fleck 5600
CD King
09-14-2009, 09:27 AM
Why does my Fleck 5600 keep regenerating every 20 to 30 mins?
Gary Slusser
09-14-2009, 10:25 AM
It can regenerate that quickly unless it is an electronic version and the programming is messed up.
So what is it actually doing when you say regenerating?
Is it a mechanical metered or electronic?
If electronic, what is the programming?
If mechanical metered, how many gallons is it set for between regenerations?
CD King
09-14-2009, 10:37 AM
Gary,
It is a Fleck 5600SE, approximately 2 yrs old. It ran fine until a couple of months ago. I have it set for 1800 gallons between regenerations. After regeneration it resets back to 1800, then about 10 minutes later it starts counting down at a very fast speed til it reaches zero. Then it starts is regeneration process all over
nhmaster
09-14-2009, 11:29 AM
Timer is not operating properly
Micro Switches or harness defective
Faulty cycle cam operation.
Here's the service and installation manual
http://www.abundantflowwater.com/5600SE_service_manual.pdf
Gary Slusser
09-14-2009, 07:47 PM
The manual doesn't mention the meter. I'd unplug it at the end of a regeneration and see iif the gallons count down then. If the gallons still count down, and the micro switches are opened/closed as they are suppose to be, I would say it was the timer.
