derousseau
I am wanting to install (in my Garage) A pump, pressure tank, and a 500 gal tank for the water to my house. I was wondering what type of pipe I should use to conect all this, copper, steel, or PVC?
Thanks
Thanks
Why not 40? Does it have to be 80?
Bob, you can't use sch 40 PVC for water.
Bob, sched 40 PVC isn't rated for hot water.
In Florida (which seems to be identical to IPC), distribution piping within the building cannot be Schedule 40, it has to be CPVC. Service piping to the building can be PVC.
Either way, the few cents you save by using PVC hardly seem worth the worry. Pipe it in copper and be done with it.
I would use PE pipe or sch 40 PVC but, do you have city water or your own well?I am wanting to install (in my Garage) A pump, pressure tank, and a 500 gal tank for the water to my house. I was wondering what type of pipe I should use to conect all this, copper, steel, or PVC?
Do I really have to post the related code and charts? You can not use sch 40 PVC for water supply or distribution piping.
I'd say you do have to post it. Maybe it's not used for either in Maine but all across this country it is used for water supply. In frost free areas across the south you can see it coming out of the ground at well pressure tanks out in the yard and along side the house/garage for city or well water supply and in cellars to pressure tanks and into garages where there is no cellar to water treatment equipment.Do I really have to post the related code and charts? You can not use sch 40 PVC for water supply or distribution piping.
