PROS and CONS?
Criddle
Idaho
What are the pros and cons of having a pump that can pump more than you need?
I have a pump now that is cycling not more than every 30 sec. when the sprinkler is on and it seems way to often. I was considering a 13GS20 gould pump.
I also seem to have very low pressure. I can only run one sprinkler at a time.
About a minute or so between cycles would be better. Need more information though to be able to give you an answer. Such as, what do you have for a tank. What is the pressure switch set at, and anything else you might have on the well itself. Just remember that sprinklers are typically pretty high demand.
