borninblue
This is my first post and first DIY plumbing job so please excuse my ignorance.
Here is the problem, I have a sink floor drain which is 1 1/4'' in size. I purchased a "floor drain kit" from HD for the install (screw together type). This is in a basement bathroom which also has a shower. The house was built in 1963 and there was no sink connected to this drain when I moved in so I had nothing to look at to duplicate. I connected the kit to the new sink (also 1 1/4'') and it drains no problems.
I thought everything was ok until I let the sink run for 5 minutes. Where the sink drain (black tube) meets the pipe fitting it began a very slow leak at the top of the white plastic fitting. It was leaking through the top very slow almost a drip. It appears after the sink runs for a while the water starts to back up partially past the p-trap back up to the black sink drain pipe. But not to the point where the sink backs up, it still drains fine. Not sure what is going on here. I have tried replacing washers in the end cap where it meets the sink drain with no luck. Tried a different lock cap with no luck still leaks out the top after a few minutes.
Now I have no clue to about venting because I do not know what to look for, but do not smell any gas coming up.
I have attached a pic to see if something is wrong with the set-up. Have tried to modify set up with no luck after 5 trips to the store lol. Thanks for your time.
-Dan
-Dan
