wallskev
08-28-2009, 05:48 AM
I am confused on the drains in my crawel sapce. Discovered this after a major blockage stoped up all lines ! Cost me over $200 :( to get cleared... The plumber then questioned the way the lines were routed.
Note from the picture that all the drains of all the fixtures from the house run into the 4" main line running North to South (Left to Right) , then turn 90 Deg run for about 8 feet ( This is where the blockage was) and Turn again 90 Deg and run without any drains connetced to it some 25 feet Back to the North ( Right to Left) in a 4" main.
Cleanoiuts are only on the 2" lines ( C and CO notations )
Makes no sense to me why the fixtures were not connected directly to the South to North Main directly without the long travel loop.
The House is only 3 years old.
Can anyone help on this :confused:?
Should I cut it all out and run each drain into the South to North (Right to Left) line ?
Thanks for Your Help
Kevin
Kevin
