View Full Version : Water pressure regulator ticking ?
Brendan
08-08-2005, 08:56 AM
Hi - my water pressure reducing valve has started to make a knocking or ticking sound. It's not doing it all the time - but when it does it's very annoying, as it's right below our bedroom !
The noise only occurs when there is no water running. If I turn on a tap it goes away.
Is the solution to rebuild or replace this unit ?
Thanks - Brendan.
08-08-2005, 10:50 AM
If you can find a rebuild kit.
Most of the time, we replace the entire prv
Brendan
08-08-2005, 05:02 PM
Thanks for the reply. Have you come across this problem before, is it common ? :confused:
