Washer stuck to copper pipe
bertie
Hi
We are trying to fit a plastic speed fit elbow 15mm onto our water pipe in our bathroom in order to connect a new shower unit to it. However we cannot remove the old copper washer used with the existing fitting :? - (I think it's called an adaptor?)
We cannot use the existing fitting as we have had the walls plastered & re-iled (they needed it!) & this has resulted in less space between the shower unit & wall. The speed fit connector gives us the extra centimeter we need to get the shower back on for a perfect fit!
We have tried everything to get the washer off but to no avail, any advice offered would be greatly appreciated.
Thanks
Assuming you are talking about a ferrule used in a compression fitting, the ferrule puller should work. It's sort of like a gear puller, they come in various sizes.
Further info
Hi
After some more internet research I've found out that it's a compression ring & nut, & the nut is stuck, it seems like a common problem, but I couldn't find any info before as I didn't know the correct terms!!
So I think a puller would be the answer, hopefully, thanks for posting back
Tools like this puller are fairly easy to find in rental stores in the US. I infer that you are not in the US since you are using metric sizing. You might shop a bit more and see if you can find a brass fitting instead of the plastic.
ferrule
Another problem might be that ferrule pullers usually only come in the size to remove 1/2"-5/8"" ferrules and you may have a different sized copper tube.
