View Full Version : Gas Hot Water Heater-Temperature control
jkcsanchez
08-15-2009, 01:33 PM
I own a Rheem gas hot water heater; temperature control dial is set to the lowest setting; water temperature still rises to a dangerous 150 degrees farenheit; Can the temperature control valve be recalibrated or replaced.
Gary Swart
08-15-2009, 02:20 PM
Yes it can and probably should be. Of course all of the electronics should be tested before just sticking new parts on and hoping for the cure. A plumber would be able to test everything and then make whatever repairs are necessary.
jadnashua
08-15-2009, 02:23 PM
Depending on the age, it might be under warranty. I'd give them a call. I'd also review the troubleshooting guide in the manual. If you don't have that, you can probably find it on their website.
jkcsanchez
08-15-2009, 02:52 PM
Thanks for your prompt responses!
Thatguy
08-15-2009, 02:56 PM
For adults this is a 3rd degree burn in 2 seconds.
jadnashua
08-15-2009, 04:04 PM
This is also why my city requires all new WH installations/replacements to have a tempering valve on the outlet. Now, those can go bad, too, but it's a secondary safety measure.
Having the water that hot has some advantages IF you have a tempering valve...it makes it look like you have a bigger tanks, and will kill any bacteria that may be in the water. It costs more to keep it hot, though.
http://www.terrylove.com/images/honeywell_tempering_2.jpg
08-16-2009, 07:40 AM
IT can be replaced, but should NEVER be recalibrated.
jkcsanchez
08-22-2009, 11:30 AM
Thanks everyone for the information provided. Since the unit is 8 years old, I've decided to install a new HWH.
