Drain code HELP!
Racerxjling
Riverside, CA
Hello
Anyone know if it is building/plumbing code to run a sink drain along the wall ABOVE the foundation? We are trying to add 3 sinks to a small commercial business. All 3 sinks will be in 1 line w/ the existing sink. We didn't want to sawcut the foundation if possible.
Thank you
Jeff
Riverside, CA
I'm not a plumber...I read a lot and lurk here. If you can provide the proper pitch for the drain - 1/4" per foot until the point where it goes down to the sewer and you can provide the proper venting, then I don't think you will have a problem. Asthetics may fail, but code probably wouldn't. The pipe needs to be supported - code would say at what intervals.
nope
Nope. The only way it could tell was by measuring how far it falls before it goes horizontally. Since it is dark inside the pipe, the water cannot use a ruler to make that determination, and so it has to guess using the time it takes, while also computing its acceleration. But it also cannot read its watch in the dark, so it has to use "One second", "two seconds", etc. which can be inaccurate for the slight difference between the two locations.
