Sill plate location ... in or out?
Lakee911
I&C Engineer (mostly WWTP)
Columbus, OH
Do I set my sill plate on my foundation out the thickness of the sheathing so that it's flush with the outside of the sheathing or do I set it back so that it's flush with the framing?
Any advantage in putting down a sill sealer if I'm not insulating or heating the building?
Thanks,
Jason
Yes, it will act as a moisture barrier between the porous concrete foundation and your wooden sill plate. Building code (here, at least) specifies that untreated wood can never be in direct contact with masonry.
../j
Thanks for info. My sill plate will be a pressure treated 2x6. Upon that I'll build a 2x4 wall. I think that I'll put down anyhow.
This is in regard to the garage that I'm building. Check out progress here.
