toilet adjustments
GabeS
Remodel Contractor
Brooklyn NY
Hi,
The plumber plumbed the toilet too close to the tub. He said there was a joist in the way. Is there a toilet that adjusts left and right like the toto. I only need a few inches here to make it look acceptable. Or an offset flange that could shift it over a bit? Thanks.
Also, do they make 6' jacuzzi's that are 32" wide?
Gabe
No way to "adjust" the toilet. The only way to move it is to move the drain and flange. I infer the toilet needs to move either left or rightThe Toto adjustment you allude to is forward and back, and is only possible with a few models. There is an offset flange that might work but it will only give a little space. Have no info on the tub.
Most jetted tubs are 32" wide.
Caroma toilets (not sure if all do or not) use an adjustable unifit adapter that can be rotated to give you a slight offset in any direction.
