View Full Version : Flange and seal questions....
Hodge
08-09-2009, 01:13 PM
I have a waxless foam seal to install. I have never used it. The kit was one that is sold with a 3/8" spacer, a 1/4" foam gasket and the 3/4" foam seal. It was suggested to be used when doing a new tile floor remodel. The top of my closet flange is flush with the tile floor. Do I need to used the spacer? I have three stackable 1/" spacers available as well if need be. Somehow the instructions for the kit have been tossed out. I am nervous about using the foam. Is a wax seal with the rubber flange best?
Thanks
johnjh2o1
08-09-2009, 02:01 PM
Use the wax seal. Foam seals are mainly used on wall hung toilets.
Hodge
08-10-2009, 05:24 AM
O.K. so I will plan to silicone one 1/4" spacer onto the flange so as to bring the flange above the level of my finished floor rather than flush. I will then use a standard plain wax seal, with no plastic "funnel" on it. After seating the toilet and bolting it down I will leave it for 24hrs before turning the water on to allow the caulk to cure on the spacer. Does this sound about right?
Thanks
Gary Swart
08-10-2009, 09:00 AM
You could do without the spacer. Just use a thick wax ring. While it is true the flange ideally rests on top of the finished floor, a little more wax ring will deal with a slight recess such as you describe.
