View Full Version : How to move a cleanout
greddy
08-05-2005, 08:34 PM
I have two cleanouts that stick into my bathroom by about 4" or so. One is a smaller cleanout--maybe 3" in diameter, about 2' away from the sink, and sticking up and out of the wall, from the level of the floor. The second one is larger--maybe 4" in diameter, near the toilet (probably a toilet/sewer cleanout I imagine).
I would like to move the cleanouts so they don't stick into the bathroom. Maybe move them to an outside wall, or behind the toilet, or some other inconspicuous place.
Is that hard to do? Does it involve jackhammering the slab? Can most plumbers do this kind of work?
:rolleyes:
08-05-2005, 09:02 PM
Most plumbers can move cleanouts, it just depends on time and money.
It should be doable though.
master plumber mark
08-06-2005, 05:01 AM
terry said it right , anything can be done
I think the money part of the equation
is going to be the issue here, especialy if its
on a concrete slab. Its probably going to be
more than you might want ot spend.
08-06-2005, 07:16 AM
Depending on how the pipe has to be revised to move them, it could make the cleanouts non-functional, and make sure the "inconspicuous" place is not also an inaccessible one when the plumber needs to use the cleanout to unplug the line.
plumber1
08-07-2005, 07:34 PM
If I needed a c.o. and mine were inside on a slab and needed to clean my sewer, I'd go on the roof and use the stack as a clean out. Or find where the sewer leaves the building, dig down and put my c.o. just outside the house. If on a slab, the sewer won't be too deep.
08-07-2005, 07:38 PM
It's obvious that you have not had to go up on the roof with a proper sized snake to rod a main sewer or you would not be so eager to do it. That's assuming they even have a 3" vent through the roof, most plumbers these days run all 2" vents.
plumguy
08-07-2005, 08:03 PM
Here roof vents are not considered a legal cleanout. Then again, who would want to go on an ice and snow covered roof especially dragging a snake. The same goes for trying to dig for a snow covered cleanout. We are still required to install a full size stack thru the roof.
