No Room For P-Trap on Washer Standpipe
DigitalJim
Rochester, NY
I am moving my washer 12' and installing a new 2" drain. Due to the placement of the washer box, a standard off-the-shelf p-trap won't fit without cutting out a large portion of the stud (vertical of p-trap falls in line with stud).
Is there any reason why a built up p-trap using 90 deg elbows would not be allowed and/or recommended? Also, is there a width limitation on a trap? I would have to extend the width on the bottom of the trap about 3" to pass through the stud.
Thanks in advance for any comments.
Why not pass through the stud with the vertical waste and then install the trap?
