View Full Version : Fuel Oil Lines Exterior Specs NJ
rlbarkleyii
08-04-2009, 08:09 PM
Recently a relative had a oil spill from the use of a brass nipple and cap on a exterior fuel line. Nipple had water in it and split. What are the NJ or National code requirements for exterior fuel lines (pipe) ?
08-06-2009, 03:46 PM
It makes no difference, if there is water in the oil and it freezes, it will break any weak spot in the lines.
nhmaster
08-08-2009, 06:36 AM
NFPA 54 and the Nat. Fuel Gas code.
Most exterior oil line piping is done with soft copper but you do still have a valve at the tank that is brass or bronze. There must have been a crap load of water in the tank though. I have never seen and exterior oil line freeze and split and it gets a whole lot colder up here than in NJ.
