sound_designer
08-04-2005, 07:17 AM
Mu auto-filler for the pool started showing signs of a leak. I have an equipment pad for all the pool stuff that is about 10 feet away from the pool. Anyhow, I removed the valve and found that the leak is actually coming from a cracked pvc coupling that is just under the surface of the concrete pad. I can even see concrete through the side of the coupling. Either it cracked when the concrete was curing or the coupling was already cracked, etc.
To fix this, I'm assuming I have to break out the concrete to get to replace the coupling.
1. What is the best way to break the concrete out? I'm guessing I only need to go a few inches around it.
2. Is there some magical pvc product I don't know of that would allow me to stick it in the existing pipe and it would expand to give me a pressure resistant fix? :)
Thanks in advance.
Thanks in advance.
