tank and pump; how to stop pump
mak123
How to stop pump automatically(not mannualy) when connected water storage tank near empty?
I understand dry running of pump is not good, so I need to shut-off pump when the storage tank almost empty...
Is there some sensor to do this?
There are float switches that will do what you want. If you are using it to directly control the power, make sure the switch is beefy enough to handle the rated motor size. An alternative would be to use a low-voltage switch and have that control a properly sized power contactor or a relay that powers the pump.
