View Full Version : caulking around toilet
turtle
08-03-2005, 07:04 AM
Question,
When caulking around the toilet which is the best caulk to use?, a waterbased caulk which dries firmer,{less chance of movement}?, or a silicone caulk. Also I've read some people use grout?, to what purpose? This is a porcelian floor.
Thanks
Turtle
jimbo
08-03-2005, 07:33 AM
Grout is sometimes used to match the floor. I don't like to use it because there is just enough movement of the toilet to crack the grout line.
I use Kwik Seal latex tub&tile because it is more user friendly. It does not set up rock hard like some G.P. caulks. Silicone is excellent, just harder to install.
Dunbar Plumbing
08-03-2005, 09:30 AM
I always caulk a U-shape around the toilet, leaving the back open so if the user(s) plunge the toilet and blow the wax ring they can instantly notice it. If it is completely caulked the problem can be delayed by not noticing, or cause structural damage and molding in regards to this problem. It is best to see the situation immediately, not down the road days/weeks/months later.
Gary Swart
08-03-2005, 01:25 PM
I like a silicone caulk in the horseshoe shape as previously described. It has been pointed out by some of the professionals that in some areas the local code inspectors require the caulk to go completely around the back of the toilet. The secret to making a nice appearing caulk is to use a wet finger to smooth the joint. The Kwik product works well and is handy for the homeowner because it is applied from the tube, but the "regular" caulking tube and gun is just as good.
srdenny
08-04-2005, 04:45 AM
I prefer Polyseamseal over Dap Kwik Seal. It tends not to shrink as much. Colortile and Hydromet both make sanded and non sanded caulks that are an exact color match to their grouts. Unfortunately, they are only available from tile distributors.
plumber1
08-07-2005, 03:48 PM
I've found that the best way to calk a toilet is to shim the gap, front rear or side. Tile floors are hardly ever truley flat. And mix up some grout, white or colored. It stays a long time and looks better than calking.
