ratkillingdog
New to this house so we weren't here when the pump was installed. The receipts state it is .75 hp set at 200 ft, replaced 09/2004. The installation and wiring job is "rough". The well is low yield and can be run temporarily dry. The problem is sporadic and cannot be duplicated reliably. I do not know depth to water, pump claimed to be set at 200'.
Many times the pressure switch contacts make and pump runs but no water is delivered, even tested open line direct from the pump. The sure remedy for this is to manually open, or bump, the contacts on the pressure switch or open and close the circut at the fuse box in the pump house, and all is good.
Here's the drill. Low water pressure in house, walk out to pump house, pressure gauge reading low 20 to 30 lbs, pump running but not building pressure, remove plastic cover to pressure switch and carefully use plastic cover to open and close points, things are good. Pressure builds and points open. Sometimes it cycles normally but the make and break drill always works. Two wires to the pump house (fuse box) reliable 240 volts to switch.
