Capping old trap drain
dabensys
I am moving the location of my bathtub. The new trap drain will not connect where the original one did, so I would like to cap off the old drain.
Here's the old layout: 1 1/2 trap arm goes perpendicular through 2 floor joists then under the ajoining bathroom's floor where it wyes into a 2" horizontal drain. I plan to cut the old trap arm off just before it goes through the 2nd joist and cap it there. That'll leave about 2' of trap arm going into the wye.
I just want to make sure I don't have to go all the way to the wye and remove it. I ask b/c I wonder if a clog could develop down the road in the wye b/c there's no longer water flushing out the 45 branch of the fitting.
Cutting Old Line
You shouldn't have a prob. with the wye clogging up. If you will have access to the end of the pipe when you get done put an adapter and plug on it and you will have a point to run a snake if you ever have problems, luck. :)
Great idea! The cutoff will be right under the bottom drawer of our middle cabinet. I can bring it up with a 90 and cap it just under the drawer. Thanks!
