View Full Version : Pot Lights - Insulation
coopns
07-24-2009, 03:07 PM
I have an exsisting fixture going in between 1 and 2 floor. Height is 8 or so inches and insulated. I bought a pot light but it is the non insulated type. Can I simply remove any insulation around that area. Is there a min distance insulation/can distance?
jadnashua
07-24-2009, 03:50 PM
The installation instructions will state the minimum free air space required around the fixture. It will normally, also be on a sticker on the fixture. You may need to make a dam or box to keep the insulation outside of those dimensions. While similar, each model will be a little different. The alternative is to buy an IC-contact rated version. They are usually not much more, but you may not find that version in a remodel version. This would require you cut then patch the ceiling rather than just cut a hole and insert the lamp.
coopns
07-24-2009, 04:59 PM
So if I remove any insulatioin anywhere near it...like within a foot, I should be ok. I saw one pot light at the store and it says within 4 inches but I didn't buy that model.
jadnashua
07-24-2009, 08:47 PM
Every one is different (but similar for similar max wattage). If the insulation is likely to migrate, you may need a dam to ensure it won't get closer than safe. If you just push it back, it could spring back later. If the room above is heated as well, then you could just remove a bunch...it is likely there for noise control.
