View Full Version : manabloc woes
thri11a
07-21-2009, 09:42 PM
ok...i posted earlier claiming i had pvc piping as supply lines...on further inspection of the manabloc website, i have the tubing they use (a hard, plastic type of tube that's a little flexible, but not much)
anyway, my supply lines under the sink are too short for my new faucet...I have yet to find the end for this tubing.
I had a plumber come out today only to tell me that he's never seen anything like this and that he doesn't believe they make ends like this anymore (which I don't believe). Then he grumbled that this is why he hates service calls.
I am convinced I will need to cut off the tubing about 8 inches down from where it ends now, and that I will need to crimp new ends to this tubing. I would be happiest if I found the male end to crimp to this tubing as I am adding a female/female extension hose from the faucet to the supply line.
Thank you for the replies.
8003
FloridaOrange
07-22-2009, 05:40 AM
Could you post a picture of your setup so we know what kind of tubing you really have?
1. If it's tubing you don't generally use a regular pipe cutter.
2. That would depend on the type of tubing, some types use x some types use y. Most tubing is connected using crimped rings, again depends on the actual type.
07-22-2009, 06:44 AM
1. A sharp knife or a hacksaw.
2. HOW you connect it depends on the type of connector you use, i.e., compression, crimp, slip on, etc. The only thing you CANNOT do is glue it together.
thri11a
07-22-2009, 07:12 PM
updated with a picture
FloridaOrange
07-23-2009, 05:51 AM
Looks like PB (Polybutylene). I'm not a plumber though so I'll defer to the experts.
SewerRatz
07-23-2009, 06:14 AM
On the end of that tubing is a brass ½" by ½" IPS double male brass fitting. You can add from there. but there might be a simpler way. Can you post a picture of the new faucet and its supply lines?
Jay Mpls
07-23-2009, 06:33 AM
Longer or extended supplies from the faucet may help.I do see a standard copper pex ring.What size is this pipe?
thri11a
07-23-2009, 09:25 AM
I added the extension hose as well as the male/male brass adapater...the problem is that below the original end, where it is clamped, there is a leak...the plumber believed the part to be compromised and replacement of that part was recommended; however, he doesn't think "that part exists anymore" haha...
so what i need to find is the part that needs to be reclamped to the original tubing...and any tools i would need to do this...the rest of it i have figured out...
i would be happiest if i found a male end to place in the original tubing so i could remove the adapter (just another potential leaky spot)...but i'm content just to get it up and working
thanks
thri11a
07-24-2009, 11:49 AM
is this the piece i am looking for? and do you clamp this piece or just push it into place?
thank you
matt
8014
mattbee24
07-24-2009, 12:42 PM
Yes, that will work.
The pipe you have there is old poly tubing that isn't made anymore. That fitting you showed in the picture will work on that tubing. That I believe is the ONLY style fitting made anymore for that particular style of pipe. The big box stores usually have those fittings. If not, you can find a mobile home parts dealer and they should have it.
Hope that helps.
thri11a
07-24-2009, 12:44 PM
I actually found a poly to pex fitting at lowes...i'm putting it in now...will update when i get it finished
my house must have been built at the tail end of poly...it's only 12 years old...man, i wish it had pex instead...hopefully i don't have these poly woes much longer once these fittings are replaced
