James^C
07-18-2009, 07:29 PM
I recently moved into a new house with a walkout basement. The previous owners or builders installed a frost-free sillcock on the outside "exposed" wall. All of the plumbing to this faucet is buried within the wall. The location is near the ground on the exposed wall of the basement. By using a 6" frost-free sillcock, the faucet sticks out from the outside of the house by 3"-4" and is prohibited from being mounted properly by securing it at the face plate. This allows the faucet to move freely in-and-out and rotate in the wall.
I would like to correct the issue, but have now discovered that shorter frost-free sillcocks (under 6") do not exist. Should I replace the faucet with a standard non-frost free design? Should I build a support frame / bracket on the outside of the house to take up the extra space so that it can be secured? Should I even have an outside faucet on this exposed wall?
Thank you!
James
Plumbers in Lebanon Ohio (http://www.psbl.com/plumbingassociates/)
Thank you!
James
